Cat D4 Full Flow Oil Filter Parts Needed
mike
12-11-2001 16:50:22
S/N 7U8977 1950 model Cat D4, parts man says hard parts not available anymore. Any help out there? Part number I have is 9F6430. This will convert my by-pass system to a full-flow system. Cat started to use the full-flow system on tractor number 12904, and the later D2s may also have the same parts. Maybe someone has a parts engine, used would be fine, What I need are the parts to just use the larger paper element filter. I think I use my housing parts, its the internal stuff I need. The one I have now, a smaller paper element slides into a brass fine mesh screen cylinder first then both are dropped into the housing. Thanks, Mike & Ken
hector gemme
02-09-2005 07:06:37
 Re: Cat D4 Full Flow Oil Filter Parts Needed in reply to mike, 12-11-2001 16:50:22
HI I HAVE SOME D4 PARTS
wrenchman
12-17-2001 00:18:00
ask over on ACMOC.org.it is a Cat site.i believe D4DAN will have what you want...
