final drive for allis chalmers 653 crawler
tbird505
01-22-2007 14:24:17
I have a allis chalmers 653 with the rt side final drive seized up. does anyone know of what might cause it,or have an idea what it takes to repair it? Or does anyone have a good rt side final drive available? Thanks Paul
jdemaris
01-22-2007 17:13:04
 Re: final drive for allis chalmers 653 crawler in reply to tbird505, 01-22-2007 14:24:17
It's got two shafts and two pairs of bearings. Just take it apart and fix as needed. Bearings and shaft though, when bad, tend to get loose and leak - not sieze. You sure your problem isn't something esle? Removing the entire housing can be quite a project on that crawler and shouldn't be necessary.
653 is basically the same machine as the HD4 if you go looking for used parts. I think the HD3 finals will fit also, but require enlarging a few bolt holes.
