what is the undercarriage?
maplehillfrm,pat
01-22-2007 21:04:03
ok here is the dumb question for the day,, what is the under carriage on a dozer that you always see them refer to as 50% or etc... is it the tracks or everything,, I aint scared of asking dumb questions, but would like an answer pat
ajk
01-24-2007 03:10:20
 Re: what is the undercarriage? in reply to maplehillfrm,pat, 01-22-2007 21:04:03
Go to the link below and read through it, it explains all about tracks that you are ever likely to need to know.
AJ
CH
01-24-2007 02:48:22
If you need anything i have New Parts, Used Parts,and manuals for that machine. You can email me for my web site.
j watkins
01-23-2007 08:43:50
Pat don,t want to call myself an expert but have 37 years i h experience.. IF you have not put any money in the td 340 and for that matter if you have you might want to give me a call on the td 340 lottts of isues that could save you some money jw 731-642-5210
maplehillfrm,pat
01-23-2007 20:11:59
 Re: what is the undercarriage? in reply to j watkins, 01-23-2007 08:43:50
thanks I appreciate it, I am hoping to get them both home sunday probably wont be until middle of the week before I really look at them. I just put another tractor in the barn that needs a head gasket so the spot is taken at this time, I will post back when I get it home and started. just what I need another project, but this one will at least save me money and earns its keep.[I am hoping....]
Daveleeander
01-23-2007 03:28:36
The undercarriage is the rails (chains that the pads bolt to), the rollers, Idlers, and the track frame.
The tracks may be stretched (there are charts to tell the length per link between pins), the bushins may be worn, the final drive cog may have worn teeth, the rails may be worn down and the vertical height of the chain less than spec, the idlers or rollers may have flat spots or worn down in diameter.
All of these wear items have minimum diameters or thicknesses. If you measure what you have, and compare to what is new size, you can get a ratio of worn to new. That is what the % figure given is refering to, current compared to brand new size.
However, I find that most of the % given are very optimistic on the older units, and are more of a wishing guess than actual measured calculation. :(
Dave
maplehillfrm,pat
01-23-2007 07:19:20
 Re: what is the undercarriage? in reply to Daveleeander, 01-23-2007 03:28:36
thanks for the info that was very informative I appreciate it, I am about to jump in with both feet on a dozer ,[IH T 340 w/6 way blade,gasser] I pick it up on sunday so I will be asking a few questions I am sure, thansk pat
