jd555a
MYASSITIS
01-24-2007 08:32:03
My JD 555A will not start from the dash starter button. When I go directly to the starter and jump across terminal it starts right up. Any idea
on what and where to look? Open to anyone who knows more than me on electrical systems which should just about include everyone. Are there any simple ways to test componets?
Myassitis
myassitis
02-08-2007 07:35:21
 Re: jd555a in reply to MYASSITIS, 01-24-2007 08:32:03
Jonathan
Like Myassitis just fine thank you
Jonathan in MA
01-24-2007 12:41:34
under the floor plate is the transmission control valve. There is a neutral start switch on top of it. Jump across the terminals on the switch. Try to start with the key. If it starts replace the switch. If it doesnt, dig large hole and bury the machine. You will then be able to change that name...
