grease gun
Ron Lupold
01-28-2007 02:00:26
Need a grease gun for JD 440 track rollers
Roy Suomi
01-28-2007 17:45:46
 Re: grease gun in reply to Ron Lupold, 01-28-2007 02:00:26
In theory a low pressure , high volume grease gun should be used with roller / idler grease.. With this grease gun you can feel the pressure build up in the roller and stop before blowing the seals out. Thats provided the seals and bushings aren't junk already..If thats the case , just pump in chassis grease till you rebuild or replace the rollers..
Lavoy
01-28-2007 17:43:36
I have new ends on hand if you need one.
Lavoy
Tom in Central Pa
01-28-2007 09:32:19
OR you could remove your grease gun tip, remove the button-head fitting, thread the hose in the roller, grease it, then put everything back to normal. I"ve done that in a pinch.
JoelD
01-28-2007 06:23:12
Called a button fitting.
VaTom
01-28-2007 05:29:19
It's just a special tip, goes on any gun. Your JD dealer has them.
