Hydraulic pump size on Oliver Crawler?
Mike
12-13-2001 15:02:15
I have a Oliver HG crawler with an anderson dozer blade. I need to replace the pump because the one that I have will not fit behide the grill without cutting it. Does anyone know what displacement pump should be on that? Also does anyone have a good used one at a reasonable cost? thanks
Albert Duroe
12-13-2001 21:00:28
 Re: Hydraulic pump size on Oliver Crawler? in reply to Mike, 12-13-2001 15:02:15
I have several front pumps but most of them came from crawlers that had the front grill cut. I think I still have a pump that came off an OC-3 loader that mounted on the side of the frame and ran off the fan belt.
Tom Graham
12-13-2001 16:48:13
My OC-4 book shows 15gpm@1750 rpm gear pump at 1250psi. That's for a loader. That should be about what you need; Sparky knows more about that than I do, and might have a pump. I hope he reads this.
