IH 500C oil pressure problem
Rick from Paso
01-30-2007 19:58:14
My 500C has been sitting a few months, I went to start it and no oil pressure registers. I shut it down right away. Prior to starting it I checked and topped off all fluids. I didn't let it run very long before shutting it down. I started right up. Any ideas? I think I had this problem last year, been cold here. I think last year I just let it run until the pressure came up. Seems like a bad way to start up a diesel that's been sitting a while.
Rick from Paso
01-31-2007 08:56:36
 Re: IH 500C oil pressure problem in reply to Rick from Paso, 01-30-2007 19:58:14
The oil pressure gauge is electric, electric sender, I will trace the wiring from the sensor.
Rick from Paso
02-02-2007 21:58:06
 Problem solved itself. in reply to Rick from Paso, 01-31-2007 08:56:36
I backed off the oil filter some and cranked the engine over to see if there was any oil pressure. Oil oozed, I tightened the filter and away she went! Oil pressure registered on the gauge? Who knows, seems to be running normally now. I guess I haven't usually let it set that long without starting it up.
