Rebuilding the hyd pump on a T-340
jackt
02-02-2007 10:23:34
Anyone have experience rebuilding the hydraulic pump on a '59 IH T340? Mine started squealing pretty bad and hydraulics were pretty feeble so I parked it last fall. Started it yesterday and it squealed at first then stopped. Now no hydraulics at all. (fluid level is OK) Suggestions?
Thanks,
Jack
Charlie
02-04-2007 09:30:44
 Re: Rebuilding the hyd pump on a T-340 in reply to jackt, 02-02-2007 10:23:34
Are you sure the screen and hydraulic filter are OK on the opposite side of the transmission from the pump., and that there is no air leak in the gasket there that could cause a loss of suction? I would check that stuff first. There is an IHC manual on the pump rebuild for this machine.
JackT
02-04-2007 15:38:26
 Re: Rebuilding the hyd pump on a T-340 in reply to Charlie, 02-04-2007 09:30:44
Thanks Charlie,
I'll check it out once the mercury moves up the thermometer a bit more--that is if it didn't all fall out the bottom last week!
JackT
