Starting to reassemble
bent1
02-02-2007 11:03:53
Everything is removed for undercarriage rebuild. new tracks, rollers, bolts, etc. Idlers rebuilt. should get the turned down sprockets back in the AM. I am planning on welding the sprocket rims on with 7018 rod. Is that the best to use. Also any issues with tempering if I do a continuous weld arounfd the sprocket?
bent1
02-03-2007 05:55:27
 Re: Starting to reassemble in reply to bent1, 02-02-2007 11:03:53
Magnet sticks. Sounds like as long as I take my time it shoud go well. Thanks for all of the input.
lauren lamb
02-03-2007 03:21:23
Bent1
I don"t know how old of tractor you are working
on, if a magnet won"t stick to the sprocket you will have to weld it with stainless steel rods, but if a magnet if a magnet will stick to it 7018
is ok ....be carefull L A Lamb
135 Fan
02-02-2007 15:58:14
7018 is the rod to use. Make sure to put a bunch of tacks all around it so it doesn't pull when the weld cools. Preheat wouldn't hurt if the steel is fairly thick and you may want to alternate welding on one side then the other to keep things straight and an even temperature all around. Let it cool slowly by itself and you shouldn't have any problems. Also burn the rods as hot as you can make a nice bead so you get proper fusion and penetration. Not so hot you get a lot of spatter and undercut. Clean the area to be welded and grind a small groove for penetration if the pieces fit flush. Dave
Grampa Leon
02-02-2007 12:00:41
This is the rod I would use [7018],and would not be concerned with tempering after welding.
