Deere 7775 skidsteer fuel tank removal
dave7775
02-09-2007 19:13:27
I need to remove the fuel tank in this machine. Looks pretty involved to get out, not sure how best to proceed. Anyone here 'been there - done that' & can give tips? I brought the Tech Manual but it doesn't give any help. Also posted this on the JD forum. thanks
justfixin
02-10-2007 10:05:30
 Re: Deere 7775 skidsteer fuel tank removal in reply to dave7775, 02-09-2007 19:13:27
set it up on blocks . remove bottom pan drop tank out of bottom. i have used a plastic weld apoxey to patch plastic fule tanks works good can get it at a auto parts store. good luck
J Plunkett
02-09-2007 19:24:09
Its a New Holland with a Deere motor,if you know any New Holland owners mabee they can help. I had a 8875 but dont know how to get the tank out, whats wrong with it?
dave7775
02-09-2007 20:23:13
 Re: Deere 7775 skidsteer fuel tank removal in reply to J Plunkett, 02-09-2007 19:24:09
Got a hole rubbed thru it - the brake linkage had been disconnected, link rubbed thru. Has been patched there once before, can't find anything at part stores to patch it with (its plastic)- all patches are for gas filled tanks. Can still get new tanks for $180 or so - figured I might as well bite the bullet and fix while I could still get parts. Great machine other than an occasional electrical problem once in awhile. thanks
