JD 310 A Should I use any sealant/adhesive on new
EDWARD1990
02-11-2007 19:35:59
I am rebuilding a Jd 310a engine. Should i use anything on the new head gasket to help seal it?
Chris Thompson
02-16-2007 10:45:32
 Re: JD 310 A Should I use any sealant/adhesive on in reply to EDWARD1990, 02-11-2007 19:35:59
super clean !! surfaces . and clean up with brake clean and install dry and torque down correctly and no problems .although if you have steel shim gaskets which i doubt i would assume that it is sandwich gasket then dry is inly way to go !! if steel shim use high tach or my preference of aluminum paint put three good coats on and let dry up a bit and install on dry block and head . and use a good torque wrench .
Bob Plumadore
02-12-2007 03:24:37
NO!
