HD 11B Hydro Angle Blade
H2
02-12-2007 11:21:43
I've got a Fiat Allis 11B that only has a 2 way blade and wondered if it was much trouble to put on the controls and cylinder on the blade to tilt it. About what would it costs used for the cylinder, hose and control valve and would it be worth the trouble? I assume any Allis 11B cylinder would work?
Grampa Leon
02-12-2007 16:37:53
 Re: HD 11B Hydro Angle Blade in reply to H2, 02-12-2007 11:21:43
Adding a tilt cylinder to an existing dozer,in my opinion,be cost prohibitive,considering needing a control valve, hoses,proper size and length of cylinder,[not just any cylinder will do]plus a lot of heavy duty welding and mechanical work.[unless of course if someone has much spare time,it would be an interesting project]if you decide to do this modification tilt cylinder diameter should be approx.30% larger[and quite beefy] than lift cylinder,length not to be such that it will cause excessive twist to remaining dozer components.
