2244 M.F. Crawler
Ron R.C.
02-12-2007 18:26:07
Can anyone tell me how to remove the pinion gear on a 2244 Massey. I have a book but it is only a parts book. Do I have to remove engine and transmission or can it be accessed another way.
Ron R.C.
02-13-2007 13:29:48
 Re: 2244 M.F. Crawler in reply to Ron R.C., 02-12-2007 18:26:07
Yes, I was talking about the bevel and pinion for the rear end. Anyhow, I ordered a book today for the crawler and hopefully can figure out how to remove it. I have a source here in the states for parts once I determine exactly what I need. Thanks for the reply though.
JimInOz
02-13-2007 16:09:20
 Re: 2244 M.F. Crawler in reply to Ron R.C., 02-13-2007 13:29:48
Ron
From memory,I think you have to remove the pinion up thru the top of gearbox.The circlip around it's bearing is awkward to get to.The bevel requires removing the final/steering units,& the steer fork on one side.
Those steer forks can be rusted in & are often hard to move.I cut mine out,but I was dismantling the machine,not repairing it.
I think St Joseph Equipment used to be MF agents...they helped me with info.
JimInOz
02-12-2007 20:24:03
Are you talking about Bevel & Pinion?
I have a good used set here (Australia) if needed.
I took mine out of a mostly dismantled unit & that was hard enough.
Jim
