$1200 !! I guess I'll never get used to some of these prices I hear. I haven't worked for a Deere dealer since 1991 - seems things have gone up considerably since then. Did you ever read the Deere spec. sheets on the 350C "certified relife" program? Deere buys 350Cs and 450Cs back, updates them and resells - at a huge price. The reason being - there is demand in the U.S. for that weight-class of dozer - and nobody in the U.S. makes them that small anymore. So, Deere buys 350Cs, updates and refurbishes, and even sticks on a new serial # tag. Last I checked, if you furnish the 350C, plus give them and extra $70,000 - they do the rest! What a deal. They put in the new-style solid isolator, a new 179 c.i. engine, and a few other goodies. I'd love to get the stuff they remove. To answer your question about the isolator. There can't be much wear on anything. The springs, anchor posts, clips, the main plate with facing, etc. must all be good. The outside of the spring-hooks need to face the proper direction (open ends away from direction of rotation), and lots of high-strength Loctite on everything. Besides that, the pilot bearing must be good and the front-shaft in the reverser needs to have the proper end-play (.002" - .004"). If the input shaft is too loose - you have to pull the reverser out to fix and/or adjust it. With the isolator, often what does them in early after a new installation is - if one of the outside clips gets cocked - and then rubs.
