JD 450-B undercarrige ?
grayhead
02-19-2007 18:52:08
Can any one tell me if there is a heavy type washer
that fits to the front cast cross support. There are four bolts that go into the C-rails.
These bolts are 5/8-11s and they have being replaced with any thing that will fit(large lock washers, 3/4 water pipe and so on) there is what looks like a area that has had a counter bore in each of the four positions
This is what isleading me to think that some kind of washer fits into them any one have any ideas?
jdemaris
02-20-2007 06:23:15
 Re: JD 450-B undercarrige ? in reply to grayhead, 02-19-2007 18:52:08
Many of the early Deere crawlers had floating track-frames - and they hammered and wore something awful. With the 450 series, Deere sold changeover kits - especially for the 450Bs - to make the front-crossbar to trackframes a rigid-mount. It used to be part # AT53397 for the kit, but now - I think it has to be bought in individual pieces. The 350 crawlers didn't get any such kit - because - when they were bolted solid, other things would crack - it just wasn't a strong engough machine. But, the 450 series handled the solid mount fine. As I recall, the 450 C series came solid when new. My point to all this - is - you're probably better off trying to find a way to mount your crossbar in a solid way. Otherwise you probably need to do a lot build-up welding and machining to make the old-style headed bushings fit anything.
Roy Suomi
02-19-2007 19:17:03
Those are supposed to be " headed bushings ". On that old style crossbar, the track frames aren't supposed to be tight. They have to " walk " some..
