420 clutch
Art
12-17-2001 08:32:50
Does an early 420 crawler have a two-stage clutch? If it does I need the parts to install the PTO.
CPeter
12-17-2001 09:55:07
 Re: 420 clutch in reply to Art, 12-17-2001 08:32:50
I don't beleive that you 420 has a two stage clutch. While you have it apart, check the splines on the shaft between the clutch and the transmission, especially the ones on the inside of the coupling. It is softer steel than the transmission shaft and the will wear. I almost found out the hard way.
CPeter
12-17-2001 09:55:07
