D333
U9 U9 CAT
02-28-2007 17:13:44
What'ts the deal on the fuel filter water drain?
Bob/Ont
02-28-2007 17:58:38
 Re: D333 in reply to U9 U9 CAT, 02-28-2007 17:13:44
Didn't have one. The plug in bottom of filter housing is to clean it out when changing filters, the knob at top is to bleed housing after changing filter. There is a steel sediment bowl under the drive housing some water and dirt will collect in it. Dump out and wash screen.
Later Bob
U9 U9 CAT
03-01-2007 05:15:18
 Re: D333 in reply to Bob/Ont, 02-28-2007 17:58:38
I'm looking at an old cat. It cranked up easy but had a little spuder to it The man said it needed cleaning out, drain the water.
Bob/Ont
03-01-2007 07:03:26
 Re: D333 in reply to U9 U9 CAT, 03-01-2007 05:15:18
There are two taps/valves on the fuel tank. One is to shut off supply to fuel system the other is to drain off any water/condensation from bottom of the tank. That is what he meant. But also shut off supply and clean out sediment bowl too.
Later Bob
U9 U9 CAT
03-01-2007 18:14:18
 Re: D333 in reply to Bob/Ont, 03-01-2007 07:03:26
Thanks Its a nice dozer with a home made root plow. pins and bushing need to be replaced, sproket has bolt on teeth. Thanks
Bob/Ont
03-01-2007 18:22:47
 Re: D333 in reply to U9 U9 CAT, 03-01-2007 18:14:18
Might be able to get them turned if they haven't been already and 3 pass of weld on rails. Feel up on the top of the bushings, track shoe side and if not worn they have not been turned.
Later Bob
U9 U9 CAT
03-03-2007 12:41:23
 Re: D333 in reply to Bob/Ont, 03-01-2007 18:22:47
No they haven't been turned I can get it done for 300 a side Or new pins bushings for 750 a side. I would like to fix it good as possable, as I haven't bought it yet. The finale drive has a lot of the bolt heads broke off The man told me he used a "thin gasket" The bolts got loose broke off? He also told me about a transmission repair, that he built up some bearing housing, suposed to be good fix , Got me worryed about running my 9U Thanks Bob
