JD 330c reverser problems PLEASE HELP
Andrew / TN
03-01-2007 14:10:05
First I lost the use of the powershift reverse on my 350c. Forward still worked fine and I changed direction via the reverse on the gear shift. Slowly I began to loose forward on the powershift. I pulled all the valves out of the valve body, reinstalled it would move but barely at all. I thought I might have a problem with the powershift accumulator so I pulled it off and took it and all the valves to John Deere dealership for inspection. They said the valves and the accumulator looked fine. I reinstalled the accumulator and valves now it will not move at all. I have adjusted the shift speed screw still nothing. What is the next thing I need to do? There are two shims under the valve closest to the engine but no shims under any of the other valves. How do I check the pressure coming to the powershift. The clutch pedal feels like it has more pressure behind it now than before it was rebuilt. I appreciate any help I can get.
Andrew / TN
03-05-2007 18:03:31
 Re: JD 330c reverser problems PLEASE HELP in reply to Andrew / TN, 03-01-2007 14:10:05
I want to thank everyone who took the time to answer my questions. Perhaps one day she will ride again but for now its getting close to planting time.
Andrew / TN
03-03-2007 06:43:36
I checked the pressure and it is very low. It would not register on my guage. It will blow oil out of the hole. What do I need to do now?
jdemaris
03-03-2007 06:52:57
 Re: JD 330c reverser problems PLEASE HELP in reply to Andrew / TN, 03-03-2007 06:43:36
You need to make sure the clutch-linkage is returning all the way. On 350s, it can get dirt jammed behind the lever on the control-valve-housing - along with the spring getting stretched. Other then that - assuming there's oil in it - it probably needs to be torn down.
But - if you have a 350C, and little reverser pressure - it's not going to move anyway - because the steering clutches are powered by the reverser.
CH
03-01-2007 18:06:39
I have a tech manual for that machine. Email me for my link.
Roy Suomi
03-01-2007 15:36:41
The pressure tap is on the top of the reverser control valve..1/8 pipe plug[probably allen , 3/16"]This is the one thats drilled straight ..Not the one on an angle....The spring with shims is probably the pressure control valve..The pressure should be around 130 to 135 lbs.. Sounds like something might have gone wrong inside...The clutch pedal only opens and closes a valve in the control valve..The clutch pedal should feel like stomping on a whole lot of nothing, just the pressure of a return spring.
original possum
03-01-2007 15:07:47
Was it rebuilt? What does a pressure test say?
