Another Hoe question
Jiles
03-02-2007 11:17:32
I have a 480D Case backhoe. Where is the greese fitting for the main hydraulic pump. It is driven off the front of the crankshaft. I can see the splines of the pump but can't find the greese fitting.
marlowe
03-02-2007 18:10:56
 Re: Another Hoe question in reply to Jiles, 03-02-2007 11:17:32
the oem ones did not have a fitting but when you buy a new one 50.00 some bucks they a zerk
135 Fan
03-02-2007 16:01:47
It probably doesn't use a grease fitting on the pump shaft. I assume it's a straight shaft with no u-joint. Dave
Jiles
03-03-2007 05:33:37
 Re: Another Hoe question in reply to 135 Fan, 03-02-2007 16:01:47
I think both of you are right. My owners manual says there is a fitting and has an arrow pointing to the crank pulley on the right side. All I can see is about 1/4 inch of pump splines going into the center of the pulley.--THANKS--
