TD35 Magneto
Tom Railsback
03-02-2007 19:01:55
My closest friend has a TD35 that we need a magneto for. The magneto must have counterclockwise rotation.
captain_crunch
03-03-2007 21:37:20
 Re: TD35 Magneto in reply to Tom Railsback, 03-02-2007 19:01:55
Tom
Try asking over on Red Power in the Construstion board there is a fellow from Canada who knows about the TD -35's
RAB
03-03-2007 09:13:26
Some of those listed below will operate either way. They just need the appropriate parts set up the right way round or the left way round, for that matter.
Regards, RAB
Glen in TX
03-03-2007 10:16:18
 Re: TD35 Magneto in reply to RAB, 03-03-2007 09:13:26
Only the Bosch MJA,MJB or MRF I mentioned would be reversible as impulse and cams for points can be changed but not so on the others with fixed cams on magnet shaft. The E-gap would be off and they won't fire right. A CW drive base mount 35º mag was real common and not hard to find. Neither are CCW base mounts. How many do you guys need? lol.
RAB
03-03-2007 13:08:49
 Re: TD35 Magneto in reply to Glen in TX, 03-03-2007 10:16:18
Yep. The E-gap will prolly be too far off even to be generating enough current energy to get a spark, when the points open, unless it is driven fast with an electric drill. Parts in at least some of those Bosch mags are already fitted and only need turning around or retiming for opposite rotation.
Regards, RAB
Glen in TX
03-02-2007 22:52:28
You detemine magneto rotation by facing the drive end of magneto and the way it turns to impulse. All mag books I have show the TD 35 & TD 40 used a CW, clockwise drive, base mount mag with 35º impulse. TD6 & TD9 did use a CCW mag however. For TD35 any mag that drives CW, base mount, 4 cylinder with 35º impulse should work.
IHC F4
Fairbanks Morse FM-X4A11 or FM-J4A11
Wico XH-184
American Bosch MJA, MJB, MRF, MRD 412
Tom Railsback
03-03-2007 17:58:41
 Re: TD35 Magneto in reply to Glen in TX, 03-02-2007 22:52:28
We were looking at it from the wrong end with the cap off the back. After reading the one post, I realized that.
We just need to come up with one for a TD35 that has a Bucyrus-Erie dozer.
Thanks for all the replies.
