I have an early John Deere 450 loader. I'm having some trouble with it. Here are the symptoms:Steering clutches don't seem to be disengaging well when going forward, especially the left side. It's difficult to steer. HOWEVER, they work great in reverse! Strangely, tapping the foot brake pedal causes the foward steering to improve considerably. Brakes seem to be sticking. Especially noticable when moving in reverse. Foot pedal doesn't return like it should. Clutches don't seem to be slipping...but rather, appear not to be disengaging, particularly the left side. I adjusted the clutches according to the service manual and found that the problem worsened.
I've pulled the fuel tank, etc and opened up the housings. Turns out the left brake pivot shaft was seizing quite a bit. I've got it loosened up now. However, I noticed that there seems to be a fair amount of play in the left side clutch pack. I can wiggle it around quite a bit. The right side has some movement too, but the left side is noticably more. Is movement in the clutch assembly normal? So, now I'm faced with trying to decide whether to put it all back together and see if the sticky brake was the problem, or if I should go ahead (since I'm already part of the way there) and tear into the clutches. Anyone recognize the symptoms and have a suggestion or opinion? I hate to put it all back together again if there's a likelyhood that I'll have to tear it all down again. Thanks guys!
