case 580k parking brake repair
greg mmmm
03-09-2007 19:38:58
is the parking brake for the 580k inside the transaxle? does everything have to be removed to fix it, or can it be done with the transaxle in place?
greg mmmm
03-12-2007 16:03:49
 Re: case 580k parking brake repair in reply to greg mmmm, 03-09-2007 19:38:58
do I have to drain the axle before I remove the parking brake?
Doug in Amarillo
03-11-2007 16:12:46
You need to determine if your 580K is a series 1 or series 2.If it is a series 1 it will have the disc assy. If it is a series 2 it will be internal.Ether one is repairable without removing the transaxleexcept if the splines are completely worn out on the series 1then you will need to replace the ring and pinion as that shaft is the end of the pinion shaft.If you need my help email me at douglasmcgalliard@yahoo.com
greg mmmm
03-10-2007 08:54:23
soon as the weather gets better I will see what I need. I just have to figure out if I need to drain the fluid first
CH
03-09-2007 21:31:17
I believe i have those parts new aftermarket email me for my link
Jiles
03-09-2007 20:42:19
I have a 580K and the park brake is on the front of the transaxle. It is just below the driveshaft and is a disc type brake. I don't know what you need but I have a used complete assembly that I will sell.
