JD 440 Crawler
pall mall
03-10-2007 06:19:40
i have a 440 loader/crawler. my reverser only works on one side as i only have one forward gear and the rest are reverse so im guess its in the reverse side. im thinking about having some one fixing it. i think the motor has to be pulled to get to it. can someone tell me what they think it would cost to have it done. just a reasonable ball park estimation. thanks for reading.
jddozermike
03-10-2007 18:40:49
 Re: JD 440 Crawler in reply to pall mall, 03-10-2007 06:19:40
May only need to be adjusted,DO NOT use it the way it is, it WILL ruin the reverser.
If you want the adjustment info email me.
Plates for reversed are 40$ eack X 10 = 400 buckaroos, been there done that, unless your railers or pressure plates are bad, thats all you will need.
And yes you need to remove engine. may as well replace main seals while you in there.
micahwinn@yahoo.com
Pete in Cal
03-10-2007 15:27:55
Try Lavoy at jdcrawlers dot com
