Info on INT B-4 dozer?
Pete Kildow
12-19-2001 06:52:38
Hi Lot's of info on this board.
Im looking for a dozer to move dirt and clean up small under brush. Most of it is under 1ft across in sandy soil and some clay .
Also to build road's, And to just play on.
I have found a Int B-4 dozer 1971 model, But would like to know if this dozer would do what I need to do ( To big or not big enough) with it?
I have a 1990 yanmar B27 trackhoe and a 1999 kubota M4700 tractor with loader, But you can never have enough toy's.
If you can give me any advice on this dozer, As good point's bad point's, What to expect to go wrong, weight?
It has new steering clutches and undercarrage about 200 hours agao..
Thanks in advance
Pete
Bill
12-26-2001 09:39:37
 Re: Info on INT B-4 dozer? in reply to Pete Kildow, 12-19-2001 06:52:38
It should read as "INTERNATIONAL BT-4 CRAWLER".
tn_pete
12-28-2001 08:39:06
 Re: Re: Info on INT B-4 dozer? in reply to Bill, 12-26-2001 09:39:37
Thanks Bill:
Would you know where I can find any info on this dozer?
Weight,Hp,And anything else ??
Pete
Milton Fox
12-20-2001 12:19:42
Pete Kildow; ----- ----- 20 / Dec. / 2001
I have the U.S.A. verision of International B-4 Crawler //
International T-4 Crawler / Neb.Test # 754(9/1960) Motor -- 4 cylinders / # 123(G)Gas Years of production / 1960 to 1964
International T-5 (and TD-5) Series; Neb. Test # 753 (9/1960) Motor -- 4 cylinders / # 135(G) Gas Years of production / 1960 to 1964 International TD-5 Crawler / Neb. Test # 755 Motor -- 4 cylinders / # 144(D) Diesel Years of production / 1960 to 1964
The International B-4 had a British motor in it, I would think that it was built the same years that the U.S.A, crawlers were (and the same Parts Catalog for the two crawlers // except for the ENGINES).
I could be wrong on this, ----- -----
Cheers, Milton
T4 - Mike
12-19-2001 15:06:22
B4??? never heard of one. Could be a T4 but they were only made 1960-65, replaced with the IH 500 crawler. Both were small models 5-7000 pounds.
Pete
12-19-2001 21:03:22
 Re: Re: Info on INT B-4 dozer? in reply to T4 - Mike, 12-19-2001 15:06:22
Do you think he ment d-4 and just made the add wrong?
Was there a d-4 int made in 1971??
Pete
