cat D2 pony motor timing
bpames
03-14-2007 20:47:52
Any help on this issue would be appreciated. Original problem was no spark on the pony motor. I found the mag wasnt even rotating due to the fact the drive gear on the mag had 2 teeth missing. I pulled the mag and replaced the gear. Now I'm wondering if anyone knows how to properly put this back together. I know to line up the timing marks, but since the gear broke it rotated several times, so i wasnt able to mark where it was when i pulled it out. - thanks
Grampa Leon
03-15-2007 16:01:08
 Re: cat D2 pony motor timing in reply to bpames, 03-14-2007 20:47:52
Need your e-mail address to send scan for mag.
timing
bpames
03-15-2007 21:47:20
 Re: cat D2 pony motor timing in reply to Grampa Leon, 03-15-2007 16:01:08
to grampa leon, my email is bpames@hotmail.com , thanks for taking the time to help
Grampa Leon
03-15-2007 05:13:10
Will scan a copy of timing marks and instructions
for your starting engine,and will send them today.
elton
03-15-2007 03:39:31
it has been awhile, but if I remember right there should be a mark on the gear on the pony motor. I had one that the shaft actually broke and I had to replace the the shaft. you will have to rotate the motor and look for a notch or dot on the side of the tooth or between two teeth. good luck
