hd11b tracks
fast69
03-15-2007 23:52:01
I purchased an 11B last year. The pins and bushings have been turned about 8 years ago and had NEW pads put on it at the same time The owner has NOT used it since, BUT he bought this NEW and has kept very good care of it I am having trouble with left track jumping off when I back up and turn at the same time The track jumps to the inside The tracks are tight BUT the left one is tight when the adj is only about 3/4 of an inch out of the adj. when the right has about 2 inchs out This happens when I am NOT on level ground PLEASE HELP!!!!1
EBEN
03-16-2007 10:54:07
 Re: hd11b tracks in reply to fast69, 03-15-2007 23:52:01
11B has screw adjusters? Check to see if the LH truck spring is damaged/broken. Make sure someone didn't install (or not) something incorrectly. If it has a manual angle blade she will be nose heavy and tiptoe badly backing uphill. Install a winch, hang some type of counter weight to offset the blade. Turn lightly on the downhill push. I have done all of these, and the winch and carefull operation work best.
fast69
03-16-2007 15:33:00
 Re: hd11b tracks in reply to EBEN, 03-16-2007 10:54:07
My 11b has grease adjusters my blade is a 4 way hyd tilt cyl on the left side THANKS ps How do I check the main spring without taking it out?????
EBEN
03-17-2007 03:56:11
 Re: hd11b tracks in reply to fast69, 03-16-2007 15:33:00
I will look at my book today,I have an 11E. Do you have the oil bath spring compartment? Rock guards? Talk to you tonight. Eb
