HD_5 transmission seal replacement
Rock_Picker
03-18-2007 20:57:03
I disconnected the engine/tranny driveshaft today. The tranny yoke will move up and down about 1/32". Does this mean the bearing is shot also? Can someone tell me where to find an exploded view of the transmission? Thanks..... ..... ....RP
hector gemme
03-19-2007 04:27:18
 Re: HD_5 transmission seal replacement in reply to Rock_Picker, 03-18-2007 20:57:03
Did you check the cap screw retaining universel joint yoke just before the seal maybe the screw is loose and you have yoke damage spline or the metal seal are no more good and I have those parts.
Rock_Picker
03-19-2007 06:21:54
 Re: HD_5 transmission seal replacement in reply to hector gemme, 03-19-2007 04:27:18
Hector: Thanks for the reply. The cap screw was tight. If I just pull the yoke out to look at it, will it go back in, or will parts move and I wind up removing the tranny to fix it?..... .....James
