HD3 Allis Oil Coming Out of Breather
speweik
03-19-2007 04:24:51
More trouble with the HD3! I got it running and when I engage the shuttle clutch, it will only move a foot or so before it dies. If I shift the transmission to neutral and engage the shuttle clutch, the motor slows down (as if under a load) and then oil starts coming out of the breather/dipstick on the transmission case! Any ideas what might be causing this? Thanks!
Bob/MS
03-21-2007 13:33:22
 Re: HD3 Allis Oil Coming Out of Breather in reply to speweik, 03-19-2007 04:24:51
you are right on. the seal has gone bad allowing the two to communicate.
Bob/MS
03-20-2007 12:08:14
may be stopped up hydraulic filter or screen in trany. Also if you have not, you should pull side plate off trany (where the two oil cooler lines come from) and inspect for sludge. this is also where the screen is.
speweik
03-21-2007 04:59:45
 Re: HD3 Allis Oil Coming Out of Breather in reply to Bob/MS, 03-20-2007 12:08:14
I noticed that the oil level on the transmission dipstick is way above the full mark. I have also noticed that the hydraulic fluid is very low. Do you think that perhaps the hydraulic pump is leaking oil into the transmission area?
