TD5 wiring and glow pushbutton
darren k.
03-19-2007 17:12:57
does anybody have a wiring diagram for a TD5.
Also what amp rating do I need for the glow plug push button. I found a 15 amp one at the auto parts store with a rubber boot. I am converting this on to a alternator. The orig light switch & the amp meter is what I need the diagram for. Thanks for your help.
patrick in ME
03-21-2007 08:27:17
 Re: TD5 wiring and glow pushbutton in reply to darren k., 03-19-2007 17:12:57
I have a TDC5 with the BD-144. The glow plugs that I use are from Champion CH28. I purchased them at NAPA auto for ~$14.00 a pop. I think my ammeter reads 30 to 35 amps when the glow plugs are employed. What a difference they make!
Td5doug
03-20-2007 21:43:33
Darren, I sent you an E-mail, mail me back & I will send you the pages as an attachment so you can read them. The glow plug circuit draws between 35 & 40 amps total, so the push button switch should be rated for something above that.
Darren K.
03-20-2007 18:18:31
TD5doug. Thanks. I tried to enlarge it but it will not. It is just to small to read. Thanks for your effort.
td5doug
03-19-2007 21:38:57
darrin, I'll e mail you the drawing from the parts book. I never could figure out how to put a picture up here.
td5doug
03-20-2007 14:44:51
 Re: TD5 wiring and glow pushbutton in reply to td5doug, 03-19-2007 21:38:57
third party image
I put the Wiring Diagram in the parts & pieces section & then copied it over here, but its too small to read
Darren K
03-23-2007 19:59:05
 Re: TD5 wiring (THANKS FOR ALL THE REPLIES) in reply to td5doug, 03-20-2007 14:44:51
Thanks Doug. That helps alot. The email worked great. Thanks for all the help.
