Case 188 - again - question?
mud
03-21-2007 05:19:25
Had an old Case guy tell me that when they lose a connecting rod and punch out the side of the block it can lead to crankshaft trouble. He told me that the block often needs to be line bored and the crank might need to be worked on or replaced.
What kind of expense do these two machine shop jobs add up too?
RAB
03-21-2007 14:44:52
 Re: Case 188 - again - question? in reply to mud, 03-21-2007 05:19:25
YOU WROTE:can lead to crankshaft trouble
Any casting poured at 1500 degrees celsius and cooled will have stress in it (like it doesn"t all cool/contract at the same rate. In the old days castings were rough-machined and then left to weather for months to allow the stress to "relieve" before final machining. Nowadays castings are produced more scientifically, but there will always be some stress in them. Now, remove a large part of that casting (leg out of bed)and it could have an effect through other parts of the casting. Only small movements are enough to affect thin walled bearings, which only have a minimal layer of bearing metal, and/or crankshaft alignment. That was not quite so important on a low revving engine with relatively huge clearances, but at 2400 rpm it is, especially if the engine has been computer designed so there is minimum "over-engineeering" incorporated anywhere in the design.
Hopes this explains it a bit.
Regards, RAB
Bob/Ont
03-21-2007 10:31:26
Hey Mud, email me.
Later Bob
Mike (mud - from KL and Y
03-26-2007 05:53:17
 Re: Case 188 - again - question? in reply to Bob/Ont, 03-21-2007 10:31:26
Hello Bob -
I saw that you answered a question I osted on the Crawler Forum on YT.
I've been trying to figure out what to do with the broke 188 out of our 450. A replacement is going into the machine. I was wondering if a repair to the block and a rebuild is worth the trouble and expense. It took 2 years to find the replacement engine.
Spring is on it's way down here. I hope ya'll are getting some fine weather up there too. Take Care-
Mike
