93 backhoe attachment on JD 2255
gttatum
03-24-2007 07:56:07
Can a commercial yellow attachment like the 93 backhoe work on a green JD 2255? My local JD house handles only the green farm equipment & they tell me they can't find out about the commercial attachments being compatible w/the farm equipment. I have a chance to pickup the 93 backhoe attachment at an auction but no need to if it won't work w/my tractor.
dozerman12
04-01-2007 19:23:00
 Re: 93 backhoe attachment on JD 2255 in reply to gttatum, 03-24-2007 07:56:07
Where abouts are you, I have a jd( I think 9305 model #) backhoe attachment at $2k in NY.
gtttatum
04-01-2007 22:03:49
 Re: 93 backhoe attachment on JD 2255 in reply to dozerman12, 04-01-2007 19:23:00
Appreciate it but too far away-am in Tx.
gttatum
03-24-2007 19:38:14
Thanks for your responses! They were very helpful. Think I need to keep looking for attachments that are a better fit for what I've got!
DGH
03-24-2007 18:19:29
The 9300 is open center hydraulics, needs 28 gpm at 2250 psi to run right. Weight 3500 lbs. An old but good Hoe.
135 Fan
03-24-2007 08:47:33
Is it a 9300 hoe attachment? If it is that's a fairly heavy hoe. You need to find out if the hoe is open or closed center hydraulics and what your tractor is. The backhoe valve may be convertable to one or the other. You'ld also need a bigger hydraulic pump to run the hoe. Most of the quick attach hoes need a power beyond adapter on the tractor loader valve to hook up the hoe hydraulics. They also usually have special mounting brackets that the hoe fits on. It's not a simple answer to your question. It could probably be made to work but might need a lot of tinkering and money to do. Someone else will probably have some more info for you. Dave
