NH 485 Skidloader Moves on its own
Formerly Pamike
03-24-2007 17:44:38
I am working on a NH 485 skidloader that when running the machine will move around on its own. I would guess the vibrations from the engine cause the handles to move a little bit. This causes the machine to move around. What is the cure for this? I see there appears to be small shock absorbors on the linkage. Do these need replaced?
JCSinGA
03-24-2007 18:31:06
 Re: NH 485 Skidloader Moves on its own in reply to Formerly Pamike, 03-24-2007 17:44:38
I'm not familiar with a 485 so I cant tell you what it is but every skid steer must have an apparatus that forces the pump to neutral or they will creep.
On the bigger NH's it's done with springs moving against a plate that the tension can be adjusted on. Up close to the steering levers.
Bobcats use a spring plate that works against the pump levers.
Alot of times lubrication helps alot when you have one creeping. Spray the springs, ball and socket knuckles anything you can see that may keep the steering levers from moving freely the full travel.
The small shocks usually just act as a damper when you move the levers I've never saw any that help center the pump.
Formerly PaMike
03-25-2007 11:34:06
 Re: NH 485 Skidloader Moves on its own in reply to JCSinGA, 03-24-2007 18:31:06
I think you are on to something. On this one there is a big spring that you can adjust the tension on with a 12 point bolt. The spring sits right up on top of the whole valve linkage...Thanks for your input. I think I will try that...
