TD 6 left brake adjustment
Brad in WA
03-25-2007 15:10:08
the left steering clutch broke free and the beast steers to the left, but the Brake has nothing but play in it.
How do I tighten up the brake? Am I underneath with the inspection plate off?
hectorgemme
03-26-2007 13:39:11
 Re: TD 6 left brake adjustment in reply to Brad in WA, 03-25-2007 15:10:08
take off the plate under the housing break and you will see a turnbuckle and loose the jam nut and turne the long nut until you have a good tention on your break pedal.
traper
03-25-2007 18:16:43
Brad//Two adj. one is slot on pedal arm below floor plate other in plate bottom of bull gear housing.With this cover off you can see condition of break lining.
