Michigan Hydro Oil Spec
Chuck Hilton
03-25-2007 16:56:10
Hi folks, hopefully someone can clarify this for me. While servicing my Michigan 125A I found the hydro oil dark and the sightglass so dark you can"t see the oil. Thinking this is a good time to change it and clean the glass I got out the owners manual. It says the hydro oil should be as follows; Viscosity Index 90-100 SSU Viscosity @ 100deg F 190-210 Pour Point -25deg
What does this mean by todays standards? Thanks for any help Chuck
george md
03-26-2007 19:35:59
 Re: Michigan Hydro Oil Spec in reply to Chuck Hilton, 03-25-2007 16:56:10
Chuck,
I have a 175A and the service note that
is added to the manual says use SAE 10w engine
oil or ATF type A . If it will use either of
those it will use universal trans fluid . I use AW 32 or 46 r&o hyd oil in the hyd system
if I don't have the UTF .
george
