Priming Fuel system Cat D4
Rick Trautwein
03-26-2007 16:40:38
need help on how to prim fuel sustem on a d4 cat
crawler ser#7u 1953 modle.
Thanks for any advise.
Grampa Leon
03-27-2007 14:39:43
 Re: Priming Fuel system Cat D4 in reply to Rick Trautwein, 03-26-2007 16:40:38
From Cat manual:First check to see that fuel line shut-off valve is open,next open the fuel filter valves,and the fuel injection pump valves.
With the starting engine running at an high idle
speed and compression release lever in the start position,the transfer pump should force the air and fuel through the fuel filter and fuel injection pump vents.When the flow of fuel through the the vents is free of air bubbles,start the engine{main],it may be necessary to open the vents several times to be sure that all of the air is bled from the system.
