Case 580B swing tower rebuild
td5doug
03-27-2007 09:35:03
I was wondering if anyone had used the modification kits available from "Equipment Parts Source Inc". They consist of new pins & bushings with weld on pin bosses with hardened bushings to replace the worn out hole in the tower casting. The kits I,ve seen like these are a straight weld on boss, but with this kit the lower tower pivot requires enlarging the upper tab hole to 3 1/2" to fit the weld in boss flush into the casting so the swing cyls will clear. Is it exceptable to open up the pivot pin tab hole that much & then weld in the boss with out weaking the casting??
