Old Magnet, "You should see oil at the final drive fill plugs." >>>>>No oil is visible and the dip stick had oil only touching the bottom 1/4". "There is no level check for the #44 hydraulic unit other than peering down the fill pipe." >>>>>No oil visible even with a flashlight.
"The pony fuel tank mounts to the carburetor/oil fill vent cross over pipe and the pony air cleaner. Something seems amiss here." >>>>>>The tank was dismounted so it could be kept below the carbureter level. If held above the carb. would overflow and gas run out through the bowl gasket. Apparently the float needs work. We held the tank high just long enough to get the pony started.
"Good luck with your run check" >>>>>Thank you!!! Overall the machine is superb. Everything worked fine. Both engines sounded great. The pony fired right up after sitting through several winter months. >>>>>Can you tell me what oil to add to the hydraulic system? I assume regular gear oil is OK for the Tranny and main rear drives? As for both engine crankcases, do you think 20W-40 is OK? >>>>In my previous D-8 I added High Detergent 10W-30 oil and it started leaking oil through the rear main like crazy! I had to add almost a qt. after every other start cycle. The D-4 should get moved to my property next week, then I'll give her a complete lube job and put'er to work. tinytec (in upstate New York)
