955K BRAKES
MARK ROBKE
03-31-2007 15:52:38
HOW HARD IS TO REPLACE THE BRAKE LININGS ON A 955K? I FOUND LINING MATERIAL ON THE SCREEN AND CLEANED IT,AND, ALSO, THE BRAKES HAVE NOT BEEN VERY GOOD ON IT SINCE I BOUGHT IT.IT DOES HAVE AN ADDED ON ROPS WITH LIMB RISERS.SOMEONE ONCE PARTIALLY EXPLAINED IT ,BUT NOT IN GOOD DETAIL.HOW EXPENSIVE ARE PARTS?
THANKS FOR ANY HELP.MARK.
Bob Plumadore
04-01-2007 14:17:54
 Re: 955K BRAKES in reply to MARK ROBKE, 03-31-2007 15:52:38
becareful in removing the cover. there are things you can break that are more expensive than the brake linings. the K did not have the sunmp on the fuel tank so it is an easy job to remove without taking off the rops. brakes should run about $200.00 per side, another 75 bucks for gaskets and seals
Bob/Ont
03-31-2007 18:32:10
You need to remove the ROPS and fuel tank to get cover off then pull the steering clutches and bevelgear shaft out. Pry the cover up with a bar to make sure you have all the bolts out before trying to lift it off with a hoist so you don't break it.
Later Bob
MARK ROBKE
04-01-2007 13:02:48
 Re: 955K BRAKES in reply to Bob/Ont, 03-31-2007 18:32:10
BOB,AFTER I GET THE COVER OFF,HOW BIG/DIFICULT OF A JOB IS IT?ANY THING SPECIAL NEEDED?ARE THE BRAKES EXPENSIVE?
THANKS,MARK
Bob/Ont
04-01-2007 18:48:37
 Re: 955K BRAKES in reply to MARK ROBKE, 04-01-2007 13:02:48
Take bolts out of each side of drum and flange connection. Need to roll tractor a bit to get all out. Slack bevelgear shaft bearings and take off caps. Lift out carefully so as to not dammage pinion and bevelgear teeth. Mark the side the bevelgear was on or take digital pic's to get it back together right.
Later Bob
