axle centre pin
edwinb
04-01-2007 05:35:15
I have an axle on a ford tractor I believe is the same as a 5 series backhoe it is an industrial version trastor . How do i remove the centre pivot pin it is about 2 inch diameter with along bolt screwed into the middle . I have the bolt out but cant shift the pin,is it a 2 part pin bolted together
JMS/MN
04-01-2007 10:32:50
 Re: axle centre pin in reply to edwinb, 04-01-2007 05:35:15
Did mine on the 4500 TLB a couple years ago. Have everything blocked securely- it is a two piece, I remember something about unscrewing the bolt part way, then whacking it to push the rear piece out? Then unscrew all the way. Parts picture shows all that is in there
