350b final repair problem
stephenb
04-01-2007 17:53:56
Was wondering if anyone had any ideas on this. I fixed my steering clutch pack last week. I changed the fibers and went over everything else to make sure all was ok. When I adjusted the clutch the dozer steers perfectly. But only forward. When i engage reverser to reverse machine moves straight back. When adjusted clutch is engaged in reverse machine stops and bogs down without turning. In order to use machine I must loosen up brake band way too much. Any thoughts on this??
dozerman12
04-01-2007 18:56:03
 Re: 350b final repair problem in reply to stephenb, 04-01-2007 17:53:56
Just wondering if you could email a scan of the service manual pages to pull the steering clutches? I have one with stuck clutches, trying to free them up but no luck so far. where abouts are the adjustments for the clutches and brakes? It look like you have to pull the sprockets to get to the steering clutches, which doesnt sound like fun.
Also, anyone have some parts, I need a track adjuster for my 350 and maybe a couple top rollers. I also could use the backhoe attachment brackets.
stephenb
04-02-2007 04:30:00
 Re: 350b final repair problem in reply to dozerman12, 04-01-2007 18:56:03
Under the seat you must remove the two square plates that give accsess to the clutch adjustment
uncle
04-01-2007 18:34:59
Go back over the adjustment procedures again. I had something like this before and I had to back everything off and work from scratch.
Brian
