Bobcat T250
Lance N
04-07-2007 21:05:54
Hello I have a bobcat T250 that I just replaced the alternator.The machine ran fine before this.After Installing the alternator the machine will start and run a vary short time and die.It has a code 14-2 Fuel shut off.Any Help would be great.Machine needs to go back to work on monday.
Thank You Lance
LANCE N
04-09-2007 07:20:37
 Re: Bobcat T250 in reply to Lance N, 04-07-2007 21:05:54
Thank You. Found Fuel shut Off Relay To Be Bad.
Lance
fort672002
04-08-2007 11:49:58
Check to see if the fuel shut off solenoid is working correctly. Have someone crank it and watch to see if solenoid is shutting the fuel off. Had a few go bad before.
