JD 350B DOZER
DRIGGERSFARM
04-08-2007 14:01:45
I'M LOOKING AT A 1987 350B JOHNDEER DOZER DIESEL,
ANYONE KNOW THE HORSE POWER OF THIS TRACTOR AND
TRACTOR HAS BEEN RESTORED AND IS IN GOOD CONDITION WHAT IS A GOOD PRICE FOR THIS MACHINE.
135 Fan
04-08-2007 18:57:42
 Re: JD 350B DOZER in reply to DRIGGERSFARM, 04-08-2007 14:01:45
If it's a 1987 it is not a B model. It is a D model with a slightly higher HP than the earlier models. If I remember it's around 48 HP and the earlier ones were 42 HP. Dave
jdemaris
04-09-2007 05:48:06
 Re: JD 350B DOZER in reply to 135 Fan, 04-08-2007 18:57:42
If it is actually a D model, and not a B, it would have a Saran-France built 179 engine.
DRIGGERSFARM
04-08-2007 15:16:16
I FORGET TO ASK WHAT ARE THE WEAK POINTS OF THIS
MACHINE AND UNDERCARRIAGE IS NEW.
jdemaris
04-08-2007 17:22:26
 Re: JD 350B DOZER in reply to DRIGGERSFARM, 04-08-2007 15:16:16
As I said at your other post, you better double check the year - that does not sound right, not even close. We sold 350Cs new - late 1970s as I recall, and a B has to be older. A 350B can have either the 152 engine at 39 horsepower or the 164 at 47 horsepower. Weak spots include the torsional isolator that likes to fall apart and sieze the engine at the flywheel, the floating track-frames that wear and crack, and the reverser.
DRIGGERSFARM
04-08-2007 17:51:01
 Re: JD 350B DOZER in reply to jdemaris, 04-08-2007 17:22:26
THANKS ALOT I THINK THE PRICE IS RIGHT ON THIS LITTLE DOZER IT HAS THE SIX WAY HYDRAULIC BLADE BUT NO ROPS ARE CAB. BUT I THINK I'M GONE STAY WITH THE CAT D3.
jdemaris
04-08-2007 18:19:55
 Re: JD 350B DOZER in reply to DRIGGERSFARM, 04-08-2007 17:51:01
I don't know what kind of price you are talking about - but a good condition 350B with an inside 6-way hydraulic blade usually brings around $7000 - $8000 in my area. And, with a bad undercarriage - sometimes $4000. One thing that Deere never did - and I wish they had - was to make farm versions of the 350s crawlers for uneven ground -with spring-suspension track-frames. Cat did it, so did Allis Chalmers - but not Deere. Even my little Cletracs have it. I used to work in an onion-farming area where all the spring plowing was done with wide-track Deere 350s. When I say wide-track - I mean the tracks were very far apart and also - the track pads were extra wide. Even those things had no type of spring suspension for the track-frames and they suffered for it.
driggersfarm
04-09-2007 12:22:28
 Re: JD 350B DOZER in reply to jdemaris, 04-08-2007 18:19:55
THANK Y'ALL FOR THE INFO PRICE IS 8900 PURTY
LITTLE MACHINE AND CAN'T NEVER HAVE TO MANY TOYS
I'M GONE PASS THIS ONE BY
