bobcat T300
Jeremy Caye
04-15-2007 08:26:28
Can anyone tell me why my T300 won't start? All the Functions are normal on the keypad and when it tells you to push the start button nothing happens. the gages and everything are working properly but the starter doesn't turn over. Is there a fuse that I'm not seeing somewhere or is this a major computer problem with the machine
JCSinGA
04-16-2007 18:10:40
 Re: bobcat T300 in reply to Jeremy Caye, 04-15-2007 08:26:28
If memory serves the starting circuit is protected by a relay instead of a fuse, however there should be a fuse to supply power for the relay but it would be in the compartment with the other fuses.
The relay should be in the engine compartment mounted on a rail above the battery. I usually just swap the wires from the starter relay with wires from the glow plug relay to check relay operation.
This is just a couple possibilities there are many more, way too many electrics on these late model Bobcats for my liking.
