D6 chain pin height
U9 U9 CAT
04-17-2007 18:26:50
how tall should the track chains be from the pin to the point where it contacts the roller.
Old Magnet
04-17-2007 19:22:27
 Re: D6 chain pin height in reply to U9 U9 CAT, 04-17-2007 18:26:50
Rail link height is measured from the back side of the grouser shoe and would be 4.00 in. high if it is the original 6.75 in pitch chain or 4.06 in. high if using the later D5 rails with the 6.91 pitch.
U9 U9 CAT
04-19-2007 00:40:09
 Re: D6 chain pin height in reply to Old Magnet, 04-17-2007 19:22:27
Pitch is the lenght, center of pin to pin, is this correct?
Old Magnet
04-19-2007 07:22:31
 Re: D6 chain pin height in reply to U9 U9 CAT, 04-19-2007 00:40:09
Correct, when checking you need to measure over at least four links and divide the distance by the number of links measured. Chain needs to be stretched to get accurate measurement, usually accomplished by sticking a pin in the sprocket mesh.
Maximum allowable wear is usually about 1/8 in. per link.
U9 U9 CAT
04-20-2007 00:35:18
 Re: D6 chain pin height in reply to Old Magnet, 04-19-2007 07:22:31
Can you change sproket teeth to make a differnt pitch chain work?
If everything is wore out the part you should put money into would be the tracks?
Thanks for the info trying to get her going again.
Old Magnet
04-20-2007 13:53:47
 Re: D6 chain pin height in reply to U9 U9 CAT, 04-20-2007 00:35:18
I don't believe you can get the 6.75 in pitch original chain any more. Most get converted to the 6.9 in pitch used on the D5 which requires a sprocket change or sprocket ring change. Can also get a segmented sprocket ring.
Undercarriage should be changed all at one time otherwise the mismatching of worn parts makes short life of any new components.
Old Magnet
04-21-2007 08:20:25
 Re: D6 chain pin height in reply to Old Magnet, 04-20-2007 13:53:47
Can't answer you on that one. Need to inquire at a track service shop. The D6C used the 8 in. pitch chain and has a much higher height at 4.78 in new vs about 4.00. You would need to know other dimensions for rollers,idlers and carriers and whether a sprocket or sprocket rim will fit.
Old Magnet
04-21-2007 10:39:42
 Re: D6 chain pin height in reply to Old Magnet, 04-21-2007 08:20:25
If you get an answer to that one, I would like to know myself.
U9 U9 CAT
04-21-2007 08:04:15
yes they are measuring 7 center of pin to pin, sprocket is wore out, I found some good rails but they have a 8inch pitch can I get a sprocket for them?
