44a D6
U9 U9 CAT
04-17-2007 18:30:09
tell me the importance of the roller frames give me a run down, I haven't had to tear into them yet
How bad is it to turn the pins and bushings?
Thanks Mike
Grampa Leon
04-20-2007 16:00:28
 Re: 44a D6 in reply to U9 U9 CAT, 04-17-2007 18:30:09
Am responding to your question on wear strips,
inside front of track frame are welded squares on which front idler slides, as required via hooked castings, which are located on each side of idler.Underneath these welded squares are wear strips which usually need replacing{usally riveted on},also parts that are fixed to idler may need to be built up with weld so they are "square" to fit wear strips.
Grampa Leon
04-18-2007 08:33:49
I pass this tid bit along whenever a track job is mentioned,note direction of track link when
removed ,as they can be embarresingly installed backwards,and many are.{when looking at equip.
this is first thing I check]
U9 U9 CAT
04-19-2007 00:45:03
 Re: 44a D6 in reply to Grampa Leon, 04-18-2007 08:33:49
Yes I checked that out Thanks
Bob Plumadore
04-17-2007 18:52:14
you tke the track off and haul them to an undercarriage shop
yu have to have a hyd press to push out hte pins and pushing and to put them back. it the trck frames are strigh dont worry about them being welded on, be sure and replace the Idler wear strips.
U9 U9 CAT
04-19-2007 00:43:34
 Re: 44a D6 in reply to Bob Plumadore, 04-17-2007 18:52:14
I haven't heard of iderl wear strips? whats that? Thanks for the info
U9 U9 CAT
04-19-2007 00:43:28
