TD6/T6
Tedd
04-18-2007 07:10:28
I am interested in an older international dozer. I have very little diesel expierience but am comfortable with gas like H's and M's (tractors).
If you had a TD6 with a bad motor could it be replaced with an "M" motor? If that is possible, would it be a strait forward replacement or not an easy hook up?
RustyRed
04-19-2007 20:47:47
 Re: TD6/T6 in reply to Tedd, 04-18-2007 07:10:28
Ditto to what Larry said about Redpower being a great source for info on IH crawlers. I am getting ready to put an M motor in a TD6 and it is relatively straight forward. It requires a different rear engine support plate, specific to the T6. You will also need a fuel pump and have to flush out the diesel tank for your main tank, the original gas tank on the TD6 was very small.There is also a different oil pump pick up tube on the crawlers to accommodate steeper angles than ag tractors. Restoman and others are a great guys on the construction part of the RP forums. Good Luck.
Larry_Galvin
04-18-2007 18:49:35
Check out the Redpower site, Restoman there has done just what you asked, converted a TD-6 to a T-6 using an M gas motor.
traper
04-18-2007 18:18:30
Tedd//TD6 and Md are same engine gas will fit in diesel chassis both have gas startup so change over not too hard.The gas part of diesel shartup same as m gas dist. coil, plug wires , Lever control turns on ign.opens fuel valve,opens valves in engine to lower comp. so it will run on gas.
