John Deere Crawler 350B Pressure problems
New To This
04-18-2007 18:37:57
I need to know how(and where)to check the pressure and I also need to know if there is an internal pressure pump. Any help is GREATLY appreciated. :)
Roy Suomi
04-19-2007 03:14:59
 Re: John Deere Crawler 350B Pressure problems in reply to New To This, 04-18-2007 18:37:57
Must be reverser....Under floorboards , under left foot as you are sitting on machine..Reverser control valve has 2, 1/8 pipe plugs on the top of valve..Put a gauge into the one that is drilled straight down [ not the one on an angle]..Pressure should be about 135 lbs in forward and reverse with manual gearbox in neutral and brake locked down..
Roy Suomi
04-19-2007 18:20:01
 Re: John Deere Crawler 350B Pressure problems in reply to Roy Suomi, 04-19-2007 03:14:59
Are the hydraulics for the loader or dozer slow?? or is the reverser [ travel ] weak???These are 2 totally different systems..Whats the machine doing or not doing??
New To This
04-20-2007 00:19:09
 Re: John Deere Crawler 350B Pressure problems in reply to Roy Suomi, 04-19-2007 18:20:01
I should've mentioned this the 1st time (sorry) but whenever you start it, it runs fine until it warms up---then it dies.
david lurk
05-16-2007 14:02:38
 Re: John Deere Crawler 350B Pressure problems in reply to New To This, 04-20-2007 00:19:09
i have the same problem as this what did you find
New To This
04-19-2007 09:29:48
Well, we think it's the hydraulics, but we're not sure, so maybe this'll help. Thanks!
Roy Suomi
04-19-2007 03:09:55
Reverser or hydraulics ?????
