Rear-end for Case 580K Phase 1 B/hoe 4X4 machine
ttman4
04-19-2007 04:56:45
Anybody got any leads for source for Rearend for this machine? Source somewhere out here in NW? I'm in C. Oregon
I'm needing a complete rearend I think....guts, housing, & everything for this recently acquired machine. I think it's an '89...haven't had time to ck things out too much yet as to what year etc.
Rearend is gutted though.
Actually, housing & axles are OK I think. maybe some other stuff too.
Thanks
td5doug
04-23-2007 07:36:05
 Re: Rear-end for Case 580K Phase 1 B/hoe 4X4 machi in reply to ttman4, 04-19-2007 04:56:45
Collins Services is in Medford Oregon,may be able to help, or point you in the right direction
http://www.collins-services.com/
AJK
04-19-2007 06:14:41
Had a look at Machinery Trader there is a few on there that might be of intrest to you at the link below,if yours has the gearshift on the right console, I would advise you that before you disconnect the rods on the transaxle select first gear and tie the shift lever in that position because if it is allowed to flop about with the rods disconnected the interlock mechanism falls apart and is a right SOB to get right again.
AJ
