Komatsu D21
Jim In Al
04-22-2007 17:23:01
I have a Komatsu D21A-5 that will not steer. Have read this forum and have checked all the mentioned suspects. My thoughts are it may be the valve body ( the valve-pump assembly that is mounted on the front of the transmission) Does anyone know what the pressure should be on this unit? Is there any way to test it? If this unit is bad, where can you get a rebuild kit or replacement for it.
Thanks
McRay
04-25-2007 15:20:49
 Re: Komatsu D21 in reply to Jim In Al, 04-22-2007 17:23:01
Take the steering clutchs adj pad off, check to see if you getting pressure to steering clutchs. The valve that contol the steering clutchs are on top of the steering clutches and under the seat. Could be a bypass valve stuck open on the steering valve. Might check plugs under the steering clutchs to see if any oil comes out of the plugs. No oil should come out plugs, steering clutches work dry.
