D6B rollers/ roller frame
U9 U9 CAT
04-24-2007 00:53:00
I need to know what the dimensions, for the rollers are so I can find some good ones and see what I got. Also need to know about wear strips on the roller frames what tolerance I need to look for.
I've found some parts, now I just need to put it all together
what kind of rod do you use to buld up track rails? Is that a good fix? My rail hieth is 3.75 from groser Thanks
Old Magnet
04-24-2007 08:38:30
 Re: D6B rollers/ roller frame in reply to U9 U9 CAT, 04-24-2007 00:53:00
An original rail would have a 3.91 in. height and be 70% worn at 3.79 in.
An original roller would have a 8.0 in dia. and be 70% worn at 7.75 in.
hectorgemme
04-24-2007 02:20:27
The new track height are 3.906 and for the roller flange I check on mine and get back to you and I have some brand new roller d6.
U9 U9 CAT
04-24-2007 08:05:38
 Re: D6B rollers/ roller frame in reply to hectorgemme, 04-24-2007 02:20:27
So my rails aren't so bad I can just fix my pins and bushing. Looks like the pin bosses are hiting on the rails though, the rollers look ok but I haven't measured them yet, I mean by ok is that they have flanges in the middel of them still. Thanks
hector gemme
04-24-2007 09:15:16
 Re: D6B rollers/ roller frame in reply to U9 U9 CAT, 04-24-2007 08:05:38
HI I check this morning my new rollers and they have 1/2 inch lipp and if your chaine are hitting it your roller are too deep use.
